TwinTurbo.NET: Nissan 300ZX forum - Until you cut some vents to help increase air flow. ;-) (n/m)
Z-Jay (Edmonton, AB)
on August 23, 2006 at 1:41 PM
Air flows down and out, not straight back. (n/m)
posted by Woody75 (Denver)
on August 23, 2006 at 01:15 PM
I'm looking for pictures or suggestions on where to mount
Dave N
10:44:11 08/23/06
you should consider relocating the battery :) (n/m)
Guapo
10:55:13 08/23/06
u can always weld on a bung to mount the nozzles if u think
Atl300zxTT
11:05:46 08/23/06
nixit mounted LEDs in the cowl over the speedo
Adam (NoVA)
11:11:58 08/23/06
My set up....
Woody75 (Denver)
11:14:41 08/23/06
Also on my nozzels...
Woody75 (Denver)
11:35:05 08/23/06
The Snow Performance nozzles do seem pretty big. You
Dave N
12:04:27 08/23/06
No pics of mine, but....
Woody75 (Denver)
13:43:31 08/23/06
Interesting. Thanks! (n/m)
Dave N
14:20:33 08/23/06
It's because you bought those crappy, thin, ebay hardpipes!
Scotts94z32
11:17:00 08/23/06
What does a jdm res look like?
Woody75 (Denver)
11:23:57 08/23/06
same as the 2+2 :) (n/m)
Guapo
11:24:51 08/23/06
engine bay, like any normal car other than the two seaters.
rufflez
11:45:01 08/23/06
That was the point of my question :)
Woody75 (Denver)
13:52:13 08/23/06
Always learning something new, did not know that. Thanks. (n/m)
rufflez
01:14:00 08/24/06
dunno aboot JDM, but the Canuck-Spec headlight reservoir
vorpalZ
12:35:47 08/23/06
wow seems like it blocks a good amt of flow thru that I/C... (n/m)
Atl300zxTT
12:54:50 08/23/06
Woody75 (Denver)
13:15:57 08/23/06
Until you cut some vents to help increase air flow. ;-) (n/m) -
13:41:46 08/23/06
Might as well just remove the wheel well liners as well. (n/m)
Woody75 (Denver)
13:44:14 08/23/06
*shrug* Take it or leave it -->
14:07:38 08/23/06
Post the before and after dyno test results please. (n/m)
Woody75 (Denver)
14:21:12 08/23/06
How could you gaurantee enough airflow (w/ fans) on a dyno
14:31:27 08/23/06
Yep, pics are from years back. Stock one is back in place.
Woody75 (Denver)
14:42:55 08/23/06
So many things to do I forgot to inspect your coolant
14:51:41 08/23/06
I might take a stab at making some rear IC ducts.
14:21:43 08/23/06
There really isn't much of a need for them.
Woody75 (Denver)
14:40:33 08/23/06
I don't disagree with that. But you also have to keep in
14:46:34 08/23/06
How effective/functional is a broken engine?
Woody75 (Denver)
14:51:48 08/23/06
LOL. If you polled all of tt.net right now I wonder what
14:58:51 08/23/06
NACA ducts is the term,
14:56:19 08/23/06
I 2nd that assessment (n/m)
CaliguyPurdue
15:15:22 08/23/06
That's the same as the one I use.
Woody75 (Denver)
13:26:03 08/23/06
It's not my car & I still rock the OE rubber boost hoses :)
Dave N
12:01:12 08/23/06
Or buy it from someone who is parting out
ZXRider(SoCal)
12:20:29 08/23/06
Or if you have a Candian Spec Model, use the reservoir for
MixManMash
12:29:08 08/23/06
Aren't those the same as the 2+2/96 coupe's?
Woody75 (Denver)
13:14:39 08/23/06
My 95 had the reservoir up front too. (n/m)
boileralum
13:40:23 08/23/06
Re: I'm looking for pictures or suggestions on where to mount
Spongerider :)
11:34:54 08/23/06
hey dave, some answers
bjamin
12:18:52 08/23/06
It looks like Michael felt your hardpipes were a good gauge. (n/m)
Scotts94z32
12:31:57 08/23/06
yep, seems so! (n/m)
bjamin
12:39:04 08/23/06
Here you go Dave
zboost(tx)
12:18:53 08/23/06
Are you parting out your car? (n/m)
12:45:04 08/23/06
The car in his sig is a 95TT, hes parting out a
EricTTZ
13:09:44 08/23/06
K thanks
13:29:07 08/23/06
would it matter if BOVs sits right in front of the nozzels?
Max865(ATL)
13:28:31 08/23/06
I don't think so,
zboost(tx)
18:49:45 08/23/06
Are they drilled and tapped?
Woody75 (Denver)
13:50:48 08/23/06
Yes
zboost(tx)
18:48:19 08/23/06
I thought WI was bigger than that. (n/m)
DVDBURN (MD)
12:21:07 08/23/06
Have you considering using your REAR washer reservoir?
14:24:24 08/23/06
FYI, front tank has the low level indicator as well. (n/m)
Woody75 (Denver)
14:29:12 08/23/06
Ack, you're going to make me go back and double check now.
14:40:46 08/23/06
Honestly I have no clue on the Cananda stuff.
Woody75 (Denver)
14:58:53 08/23/06
Here in the People's Republic of MA - or the "Commonwealth"
Dave N
14:42:23 08/23/06
You're not allowed to use "washer fluid" in your state?
14:48:33 08/23/06
No that wasn't what I meant to say. What I was getting at
Dave N
14:58:47 08/23/06
LOL, ok I was assuming you'd install a separate switch for
15:01:44 08/23/06
